Weel Horse GT 14
Andy (MN)
05-05-2007 06:30:00
It's a '69 GT 14 with hydrostatic drive. I recently changed the rear hubs so I could run 5 hole car rims (wide) and I noticed that the axel shaft can bee pulled out far enough to disengage from the differential . Did I wreck something ? Is there a snap ring in there or somthing?
William Pearson
05-05-2007 17:47:09
 Re: Weel Horse GT 14 in reply to Andy (MN), 05-05-2007 06:30:00
Andy,
Opps is all you can say. When you pulled the hub off you must have broken the snap ring which holds the axle drive gear on the shaft inside the differential. You will have to remove the transmission and split the case to make the needed repair.
I gather you had a hard time finding replacement tires which is why you wanted different rims.
Bill in Richmond, Va.
