good information site for BS engine
baler 46
04-17-2007 20:14:16
Hi
Looking for a site for information on a 18 hp Briggs& stratton engine.Want to know if this engine has a fuel pump on the carb? It wood not start the other day when i tried to start think the fuel pump went out the carb need carb kit.Had to run it with the chock pulled out to keep it running. Think i need a book the one i have is not new enough for that motor. thanks
not needed
08-21-2007 19:50:00
 Re: good information site for BS engine in reply to baler 46, 04-17-2007 20:14:16
i nee the specs on a briggs 18hp twin, cast iron bore
joe csuti
04-19-2007 19:53:04
Goto briggs website,goto manuals section,enter mod & type#s,you can view online or download parts list to view & printout later,carbs on pg 6&7
Bills1450
04-19-2007 19:51:36
Fuel pump is on front of carb - it is a pulse (diaphram) type that operates off of engines vacuum. Usually if engine will run though it's dirt / varnish in carb and not the pump. you may get away with cleaning it but if not most carb kits for these include parts for fuel pump.
baler 46
04-19-2007 03:50:18
Hi
Here are the model of the engine/ model is 422707,type 1505 01,code 90020812. TWIN 11 cast iron bore 18 hp
JT
04-18-2007 15:57:32
You have found a good site right here, but if you want any help, you need to post the model, type, code off you engine, then you might get what you are looking for, but without that, it is a shot in the dark to give you an answer.
joe csuti
04-18-2007 04:09:48
Before tearing carb apart or pump(if eng has)check that fuel line between tank & carb(also outlet in tank)is not plugged or restricted,replace gas filter,same may be restricted,drop carb bowl & check for a load of dirt/water in same,also check anti-backfire sol on carb(if carb has)that same works electically & that plunger retracts all the way & is not stuck or sticking.If above fails to get eng running try going to your local mower dealer with mod & type# and see if he has a repair manual covering your eng,as you didn't mention mod & type#,there are 5 possible manuals to cover your eng depending on style,1 cyl L head,2 cyl L head,1 cyl ohv,twin cyl vanguard ohv,twin cyl intek ohv,if your dealer doesn't have,try going to briggs website in shopping section & order one online,briggs used 2-3 different carb mfg on their engines,you have to know which carb you have.
