Stator on Kohler k321
Andy in Ct.
04-16-2007 13:26:45
Does it matter the position of the stator on a Kohler k321? There doesn't seem to be any info in the service manual. Thanks
Kent of SWMO
04-17-2007 06:10:31
 Re: Stator on Kohler k321 in reply to Andy in Ct., 04-16-2007 13:26:45
No, you can mount it any of the 4 way it will bolt on. The problem would be a way for the wire to exit. Mount the stator with the wires at the twevle O'Clock position and the wires pointing to the cylinder.
Kent
JT
04-16-2007 15:10:35
no, it does not matter, but you can only put it one way for the wires to come out and hook up to the wiring in the tractor and the stator.
Andy in Ct.
04-17-2007 02:37:02
 Re: Stator on Kohler k321 in reply to JT, 04-16-2007 15:10:35
The wires on the stator are towards the bearing plate. But if I understand correctly the stator doesn't have to be in a certain position like at a 12 o'clock or 3 o'clock etc. Is that right? Thanks
