mowerdecks
Ben Lanpi
04-11-2007 14:59:45
Took the mower deck off for plowing, Now getting ready for grass cutting. Question is the deck is rusty and caked with grass. (it's 2 years old) If I clean the rust and grass off what kind of paint can I put on to keep grass from sticking to the under side of the deck.
Thanks Ben L.
JoeK(WI)
04-13-2007 07:00:22
 Re: mowerdecks in reply to Ben Lanpi, 04-11-2007 14:59:45
Underside of deck is about the most horrible environment there is for paint.On my own,I clean it very well,coat with anti rust primer,then couple/three coats of good anti rust enamel.Keep it clean and it should hold up for a couple seasons.The stuck on grass holds moisture,and creates acids while decomposing so it's important to clean it out after use.
