Cub Cadet 100
austin8214
04-03-2007 18:45:13
I have recently purchased a cub Cadet 100. I have now found out it has a bad starter generator. My question is how much is this unit worth in perfect working order? I only have $200.00 into it but I really hesitate to invest more money. All sheet meatal is nice and paint is nice I can email pics if someone want's to see.
RN
04-04-2007 09:57:49
 Re: Cub Cadet 100 in reply to austin8214, 04-03-2007 18:45:13
Starter-gen units? Brushes are a wear point, clean dust out with air or electric cleaner- I used to use CRC. Switch/regulator/control box is the other possible problem- contact points can be burned/corroded, often can be cleaned, adjusted and back in service. Check for general dirt and corrosion at terminals. RN
JT
04-04-2007 07:19:03
The tractor is worth a lot more than $200.00 if it is good shape and running, the str-gen could be rebuilt for less then 50.00 or take it apart yourself and clena it up, normally that is all it takes.
austin8214
04-04-2007 13:37:04
 Re: Cub Cadet 100 in reply to JT, 04-04-2007 07:19:03
Well when i got this tractor it was wired wrong that is why i think it is totaly shot. But I will pull it apart and clean it up first as you advised.
jb9959
04-04-2007 05:13:33
You can buy a new starter/generator on E-Bay for about $120. Used ones go for ~ $50.
Dannie
04-04-2007 02:32:27
To save you money just sell me the cub for $200 and I will take it.You may be able to have the starter generator rebuild.A new 1 was about $200 3 years ago try for a good used 1.Good Luck.
