Briggs 16h Twin II Problem
bford
08-13-2006 09:49:31
I"m having a problem with my 15 year old motor, a Briggs & Stratton 16 horse Twin II. It runs really hot after 10 minutes or so, and loses power. I changed the plugs and oil, didn"t smell gassy. Is there something that would cause oil to not get to the cyliders? On a diff forum someone said they think it has an oil pump bu wasn"t sure. I pulled off the tin covers, there"s no grass or anything blocking the air.
El Toro
08-13-2006 11:19:26
 Re: Briggs 16h Twin II Problem in reply to bford, 08-13-2006 09:49:31
Are you sure the engine is getting enough gas. Running lean will cause an air cooled engine to overheat and from late timing. Hal
Bob
08-13-2006 11:01:10
I'm not sure how your engine is set up, but is there a possibility of a partially-sheared flywheel key causing late ignition timing, and subsequent overheating?
Also, some engines had trouble with exhaust valve seats coming loose when hot, and moving up and down with the valve, keeping the port blocked, causing weird running symptoms.
joseph brasfield
08-13-2006 10:23:09
that was me stating it had an oil pump , but if it dosen't have oil filter it don't have an oil pump, it has an oil slinger, is the valves seated good, i have a friend that works on briggs eninges he told me to ask is the exhaust pipe getting red if so the vaves is the problem let me know what you find out about the exhaust pipe
joe
bford
08-14-2006 10:48:00
 Re: Briggs 16h Twin II Problem in reply to joseph brasfield, 08-13-2006 10:23:09
I didn"t see the exhaust get red. It starts up great, with choke off it fires right up and runs great. After 10 minutes or so it started to bog down, when I pop the hood you can barely touch the fan screen. I guess I"ll try adjusting the carb, but as good as it runs it doesn"t seem like it would be that far off.
