never starts
bdunegan
05-05-2006 08:36:47
have an 18hp opposed twin that will not start without squirting a little gas in cylinders. when started, runs like a top. have replaced fuel pump twice (both new ones) replaced vacuum line to block, replaced all fuel line. (tank sits higher than engine, originally gravity feed engine), new fuel cap, have tried blowing air into tank to force feed. can take fuel line off at pump, and gas is there, factory rebuilt carb. will not start unless prime cylinders first. runs fine after that, and will restart unless sets for a while, then back to square one. new coil and plugs, plenty of spark. anyone ever had this problem? any ideas?
Kent of SW MO
05-06-2006 12:47:35
 Re: never starts in reply to bdunegan, 05-05-2006 08:36:47
Chokes not closing all the way. Readjust you choke control wire at the carb.
Kent
El Toro
05-05-2006 16:16:11
You may want to install a primer line that will squirt that gas directly into the intake. Snowblowers use this feature and I have it on a leaf blower. Hal
Greg_Ky
05-05-2006 14:22:07
Sounds like the choke is not working or out of adjustment.
bdunegan
05-08-2006 05:38:20
 Re: never starts in reply to Greg_Ky, 05-05-2006 14:22:07
thanks for the replies. the choke is closing all the way shut. this is the first thing i tried. the carb bowl is getting gas to it, just not pulling into cylinders to ignite. it is a factory rebuilt carb with all new parts. plenty of vacuum to fuel pump, and pump is pumping fuel. just not letting it into cylinders. any more thoughts?
Rustyj14
05-11-2006 11:56:30
 Re: never starts in reply to bdunegan, 05-08-2006 05:38:20
run a compression check on your engine! Low compression means either bad valves or valve adjustment, bad rings, worn out engine, or some other cause! Low compression/worn rings, could cause the engine not to draw fuel!
