Cub Cadet 680 wiring
badcub
04-17-2006 19:28:40
Where can I find a wiring diagram for a Cub Cadet model 680 or at least a part # for ignition switch ? I recently got one that had a blown engine - got that changed and relixed switch was missing. Also, 2 of the wires going into the switch were pulled out of plastic plug. I could probably figure out wiring if I could get the right switch.
skip176
04-18-2006 03:04:18
 Re: Cub Cadet 680 wiring in reply to badcub, 04-17-2006 19:28:40
I found mine at ihregistry.com there is a section under referances for the differnt wiring of the cubs. Hope you can find yours there.
R Bedell
04-18-2006 03:02:34
The model 680 was the Yellow & White version of the Red model 1282. Same tractor, just different colors and model numbers,
The Ignition Switch would be Part # 725-3021.
There are two different wiring diagrams for this model, depending on the serial number range.
Sorry, I have no clue what a "relixed switch" is...!!!
If you would like, I could send you the correct diagram if I had an Email Address.
badcub
04-19-2006 10:19:09
 Re: Cub Cadet 680 wiring in reply to R Bedell, 04-18-2006 03:02:34
Sorry, just bad spelling - was supposed to relized it was missing. Overlooked it when purchased tractor - other things seem minor when engine comes in a box LOL !
