mtd pro series lawn won't start
andyinottawa
04-11-2006 16:13:12
I just replaced the flywheel on my briggs , fired the mower up ( without the dipstick in oil all over , ) shut the motor off saw smoke (I assume from the oil spewing) , went to restart and the starter ring gear broke , replaced ring gear now the motor spins but won't start , cleaned the carb, did not adjust the carbs , changed sparkplug engine spins and gives a poofing sound but does not start , there is a small spark and gas is getting onto the plug but will not ignite any ideas ?
chris sweetland
04-13-2006 21:05:18
 Re: mtd pro series lawn won't start in reply to andyinottawa, 04-11-2006 16:13:12
glad we could help
chris sweetland
04-12-2006 08:09:39
hammer it on! it should slide on easy then tighen the nut down as hard as possable using a strap wernch to secure the flywheel
andyinottawa
04-12-2006 11:22:38
 Re: mtd pro series lawn won't start in reply to chris sweetland, 04-12-2006 08:09:39
thanks problem solved it was the flywheel key !!! you guys are great !!!
now if I can only get my wife to use it while I drink beer it would be perfect !
chris sweetland
04-11-2006 17:42:11
when you replaced the flywheel there was a little keyway on the crankshaft stub that has to be lined up with no groves or wear on it there olny like $.07 to replace
andyinottawa
04-11-2006 18:51:49
 Re: mtd pro series lawn won't start in reply to chris sweetland, 04-11-2006 17:42:11
thanks I realized after I posted that you must have meant that piece , I did look and the shaft did move ,and the nut probably wasn't tightened enough , how hard should i hammer the wheel back on ? I want to make sure its seated properly ( i didn't realize the washer was bowed thanks !
chris sweetland
04-11-2006 16:41:29
check the fly wheel key breaking a ring gear takes some force i bet it sheared
andyinottawa
04-11-2006 16:56:28
 Re: mtd pro series lawn won't start in reply to chris sweetland, 04-11-2006 16:41:29
what is the flywheel key ? it was the nylon gear off the starter that broke , but the engine did start earlier , when i run the starter I do feel air from the exhaust
thanks
andy
rustyj14
04-11-2006 17:44:28
 Re: mtd pro series lawn won't start in reply to andyinottawa, 04-11-2006 16:56:28
The flywheel key is a small aluminum piece, rectangular in shape, with rounded ends, which goes in a slot in the top end of the crankshaft, and matches a similar slot in the flywheel. If there was any hard shock to the flywheel, or maybe a backfire, or a loose flywheel nut, it could have sheared the aluminum key! If you do find it sheared, and if you do take it apart to replace it, make sure you tighten the flywheel nut very tight! There is what looks like a flat washer under the flywheel nut, but it ain't flat! Look carefully at it, and you will see that the washer is slightly domed. the high side of the domed washer must contact the nut. This takes the place of a lock washer! Although some of the much older engines did have lock washers!
