I just so happen to have the trans out of an R72 part on my bench. The input pulley would only turn 3/4 of the way each direction. I split the gearbox, it's held together with small bolts, and packed with grease inside. Mine has a small motorcycle type chain inside it that connects the two shafts inside. My chain was broken. A complete new chain from JD was $13- Just take it apart- what do you have to loose? Very simple gearbox, has "Manufactured by Techumseh gear division" cast into it. My R72 was a dump bound refugee, left outside in the rain with no air cleaner for years, I found why it was parked- sheared $1.10 flywheel key on the 8hp Briggs. My deck looks great. The worst part of the mower is the battery tray is rusted off due to the battery leaking. Some 1/8 X 1" angle from Home depot will fix that. I should have about $200 in it by the time I'm done, I have no intentions of making it pretty, just want something to mow my big flat area with and make it easier to move my small boat on it's trailer around.
