Where are Eaton 11 Hydro pumps used? Repair Info N
apekim
02-10-2006 05:50:46
I have a Bolens Eliminator 1900 and the input shaft on the hydro pump is wobbley. I can not determine if the pump worked since I got the tractor without the engine. The previous owner said it leaked.
I would like to repair or replace the pump, but not break the bank. If I knew where this model pump was used, I might be able to find one for cheap. I have a Jacobsen GT hydro rear end somewhere out back, but I think they used a Sundstrand hydro, but I am not sure.
Mike
Dean in MN
02-11-2006 07:32:50
 Re: Where are Eaton 11 Hydro pumps used? Repair In in reply to apekim, 02-10-2006 05:50:46
Depends on the year of the Jacobsen, but the mid 70's to early 80's models used the Eaton 11 pump.
ray martin
02-10-2006 17:12:38
HI THere
That Eaton 11 hydro had two shafts 3/4" keyed or 3/4" splined they are around $40.00 each, e-mail me at rjmartin1200@aol.com and I will get you in good direction. Ray Martin
