rpm on a engine
baler 46
10-16-2005 15:46:52
Hi i need to know what the rpm are on this engine so i can replace it.It is a brigg and strattion 9 hp.model is 23 abs.type 0021 01.serial number is 811241. Its very old cast iron bore.Its on a 6inch grain augar with 3 inch pulley on motor,and 10 inch pulley on augar.This engine doesnot run good so im going to replace it need the rpm to replace with the right speed on augar. thank you
Kent of SW MO
10-17-2005 06:11:59
 Re: rpm on a engine in reply to baler 46, 10-16-2005 15:46:52
baler46,
Does your engine run ok at idle but as you increase it's speed it starts missing and running poorly? If so, you have a bad coil. Every one of the B&S Model 9 thru 23's that I have and collect have this problem. This is B&S's Magnematic ignition. The coil, P/N 290880, from B&S is over $100.00. You can find them "Made in China" for $30.00. If you can get you hands on a November 2005 issue of Gas Engine Magazine you will find an artical on my coil modification for these engines using a later B&S coil. You can find these coils on old push mower engine and with a little labor you can fix you engine for little cost.
Kent
Irv Slagter
10-17-2005 04:38:32
That is one of those good old long stroke engines with a lot of torque and low rpms. I think gene's pretty close on ont the speed. I'd fix it, too.
Irv
Dannie
10-17-2005 01:19:51
That engine is rated at 3200 rpm at idal & 3600 at top speed.
BigBill
10-16-2005 18:30:20
I assume you are runing current engine at full throttle ? If not then max. speed doesn't matter much as you can vary it with the replacement. This ,of course, only applies if yours doesn't have a gear reduction unit on it - that creates a whole new view on things.
Dirty ED
10-16-2005 18:03:34
Copy and paste this site:
Link
It may give you what your after, don't really know, I haven't done the research for you, just pointing you in the right direction. But I think if it were me I'd just fix the engine I had. DED
Gene Davis (Ga.)
10-16-2005 17:47:23
I have an almost unused military surplus 23 series B/S that is set yo turn only 2800 rpms and they rated it at only 7 hp.
gene (missouri)
10-16-2005 17:25:55
Could find nothing specific in my B&S manuals. Generally top speed- no load - range is 3600 to 4000 RPM.
I think that with a little math you can figure out how many engine RPMs you want/need if you know how many RPMs you want the auger to turn.
Gene
