Push Rod comes off
bankash
09-27-2005 11:23:25
What would cause a push rod to come off repeatedly? This is on a Brigss 25 hp Intek OHV Twin.
Thanks
Debbie
jd b puller
09-27-2005 20:47:44
 Re: Push Rod comes off in reply to bankash, 09-27-2005 11:23:25
bankash - If you put the pushrod back on WITHOUT adjusting the lifter (just push the valve in) what is your valve clearance?
Most of the ones I've seen were from running either bad gas or High Octane gas. Nothing wrong with high octane, it just doesn't add any power and it typically has more additives, which tend to gum up the valve stems.
JT
09-27-2005 17:14:36
Everyone we have had in the shop doing this was from lack of maintance, valves were all gummed up and sticking
stronics
09-27-2005 17:05:38
That seems to be a common thing on these Briggs twin OHV. I'll bet I've had ten this summer with the same thing and ones that haven't fallen off yet have had a much as .070" inch clearance. Some have had frozen valves and broken the push rods. It seems that they get way too hot. I put in synthetic oil to help.
David
lucasss
09-27-2005 14:18:09
sticking valve
bankash
09-27-2005 19:55:17
 Re: Push Rod comes off in reply to lucasss, 09-27-2005 14:18:09
But when we took the valves out I cleaned them really good. Is there something else I could check on them?
Thanks
Debbie
bankash
09-29-2005 06:10:33
 Re: Push Rod comes off in reply to bankash, 09-27-2005 19:55:17
GOT IT..... ..... ...
Don't laugh but we have discovered that we were on at TDC. No longer a problem.
Thanks to all.
Debbie
