Cub Cadet Hydro release lever
BR
09-22-2005 10:43:17
Hey,
Does anyone know how the release lever for the hydrostatic transmission works on a cub cadet 1250? The lever is missing on mine so I can't push the tractor around when I need to. I took the cover just in front of the seat off to see where the lever is supposed to connect but it wasn't obvious. I am wondering if it connects to the shift linkage somehow or what. I was hopping that I could make a new lever and get it working.
The tractor also tends to creep backward when it is running with the brake on. Anyone had that problem?
Thanks,
BR
R Bedell
09-22-2005 16:05:32
 Re: Cub Cadet Hydro release lever in reply to BR, 09-22-2005 10:43:17
Go to this link for additional information
cadetpwr
09-22-2005 15:49:37
The lever pushes down on a pair of buttons that are on top of the hydro pump, that releases the presure and you can slowly push the tractor. The hydro creep is very common on cubs, go to ihregistry.com and look in the faqs, there you will find how to adjust the hydro linkages, or just sign up and post, lots of die hard cub fans there, myself being one of them. Cheers Mike
