Valve seat removal
bankash
09-06-2005 19:27:02
Hi everyone,
We are wondering if there is a way to remove a valve seat if a "special" tool is not available.
Can someone advise?
Thanks for all that you do!
Debbie from NC
Steve Ford
09-07-2005 10:35:36
 Re: Valve seat removal in reply to bankash, 09-06-2005 19:27:02
If you have an arc welder, the following has worked for me. Lay a small bead around the inside diameter of the seat. You only need to go about 1/3 of the way around. When it cools, the seat will fall out.
lucasss
09-07-2005 05:05:19
goodson.com has some.
