JD 420 won't stop
Bigrig BA
08-28-2005 10:04:36
JD 420 L & G Tractor won't stop when the key is turned to off. I have to disconnect the battery and then it will shut off.
tractornutjd
08-28-2005 17:49:34
 Re: JD 420 won't stop in reply to Bigrig BA, 08-28-2005 10:04:36
Hello BIGRIG. Your 420 need power to the coil pack to run. Somehow your key switch is not shutting off power to coil. Check to see that a wire didn't short out and creating a constant power to the coil. Good luck.
Bigrig BA
08-28-2005 19:37:32
 Re: JD 420 won't stop in reply to tractornutjd, 08-28-2005 17:49:34
I did check for shorts there. I also checked both fuses even though they may not be assoc. I converted this 420 to a new Honda engine from small engine wharehouse. I will call them tommorrow as they have me using both my starter sol. in the 420 and the starter sol on the honda with a jumper wire between the 2 large posts on the honda starter sol.
