Ford YT-16H spindles (continued)
Benjamin Jr.
07-29-2005 20:05:28
I finally got the nut off, and the shaft taken out of the case. There are two sets of bearings. The one on the blade side of the caseing seems to be pressed onto the shaft, probably impossible to replace. The other just came off like any other. unfortunately, both sets of bearings don't seem to have any play in them. The second mentioned bearing fits real tight into the caseing too. But the other bearing (blade side) doesn't seem to fit that tightly into the caseing. Does this mean the caseing is bad? Or is the unreplaceable bearing bad? I'm not sure what to do here. Also, were there supposed to be any kind of plastic seal between the bearings, or something of that sort? All I found was chunks of very cooked grease, and I know what that looks like too. Any suggestions?? Thanks!!!
