wheelhorse clutch
bdunegan
07-16-2005 08:25:30
have a wh c-165, and it needs a new pto drive clutch. this mower has the horiz shaft kohler, and the clutch is just a disc on the pto . have heard that you just replace the pads, but if so, how do they come off of the disc, and how do you put new ones on. where can i get them, and about how much do they cost?
bdunegan
07-17-2005 14:57:00
 Re: wheelhorse clutch in reply to bdunegan, 07-16-2005 08:25:30
went to toro master parts viewer, got number for clutch disc(103817). went to rcpw site, and can come up with no matches at all for clutch. anyone have any more suggestions?
2cents
07-17-2005 17:24:38
 Re: wheelhorse clutch in reply to bdunegan, 07-17-2005 14:57:00
I went to rcpw and the part #103187 has been superceaded to #94-6650 price for the assembley is 35.59 copy and paste this it should take you right there...-http://search.cartserver.com/search/search.cgi?cartid=a-8491&category=LawnBoy04&keywords=94-6650 This is the same clutch as mine I have a B-80..2cents
Gregg in ohio
07-16-2005 16:03:38
The clutch material should be riveted on with brass rivets..they are on mine..one guy has done this ,removes the rivets and the lining and got some clutch material and cut to fit and used jb weld and got along just fine..seems the only way to fix it so far..gregg
2cents
07-16-2005 14:32:12
Go to-https://lookup2.toro.com/partdex/index.cfm?xCaller=Toro
Enter your model # in the master parts viewer- then view attachments and drawings, find the pto parts list and get your part # then go to rcpw.com and see how much it will cost you+ shiping or watch ebay their in there all the time ...2cents
Robert in W. Mi.
07-16-2005 14:17:51
You "use" to be able to just reline the clutch disc, but several years ago WH decided to just sell the whole new disc instead.
I guess you won't have to worry about how to install the new lineing now... :>)
Robert
JT
07-16-2005 09:45:11
probably cost more than a new PTO disc from Toro.
