wheel horse d 180 wont move
AndrewD
06-20-2005 22:10:39
i bought a wheel horse d180 a few weeks ago. i was told it had been left outside for 2 years. i got it running, but it wouldnt move. i drained all of the water and oil out of the tranny, flushed it, then put new filter and oil in. now it will move very slowly on level ground, but only level ground. the 3pt works, but seems slow. am i looking at an easy fix or should i part it out. any help would be appreciated.
Gregg in ohio
06-21-2005 09:22:27
 Re: wheel horse d 180 wont move in reply to AndrewD, 06-20-2005 22:10:39
check the tow valve see if its in the tow position they might have put it there to move it..it wont move in drive the drive position..you can only drag it..unless the valve is positioned right..gregg
AndrewD
06-21-2005 13:13:24
 Re: wheel horse d 180 wont move in reply to Gregg in ohio, 06-21-2005 09:22:27
the valve is in the drive position. thats the first thing i checked when i got home. u can push the tractor around with the valve in the drive position as well.
Kent of SW MO
06-22-2005 05:52:20
 Re: wheel horse d 180 wont move in reply to AndrewD, 06-21-2005 13:13:24
The valve MAY be stuck in the open position after sitting this long outside.
Kent
AndrewD
06-23-2005 20:15:40
 Re: wheel horse d 180 wont move in reply to Kent of SW MO, 06-22-2005 05:52:20
i believe the valve is working. i took it out and put it back in. if u back it off one turn like it says to the tractor stops what little movement it has. turn it back and the tractor will move a little.
