Damper price for Cub...can this be right?
Baldrick
06-18-2005 08:03:02
My 1996 Cub Cadet 2165 seem to be having some problems with the drive linkage. I'm thinking it may be a shot damper because it very slowly returns to neutral. I know that there's an adjustment, but the problem seems to in either foward or reverse.
I've checked the springs and lubed well. When in the neutral position, the damper has zero tension on it and just sort of flops around on the mounts. I checked everything else I can see and all looks fine. Does anyone know if this damper should have a return spring in it or is it just to dampen movement in either direction?
The part is an 727-3090 Damper and I only found it one place online and the cost was $50.69. This thing is only 5/8" Dia. and 10" long!
Does this price sound right?
Thanks.
JT
06-18-2005 10:41:12
 Re: Damper price for Cub...can this be right? in reply to Baldrick, 06-18-2005 08:03:02
Depending on what you may be looking for, the dampers are expensive, most can be got for about $35.00, but they are $55.69 through MTD. If you can get me a picture of it, I might be able to find one cheaper.
