Sears Suburban 12 magneto
Bella Kaldera
05-30-2005 18:51:15
I took my old orange sears to the shop when it started running intermittantly and Jody my mechanic said that the magneto was an old type that used no breakers and he couldn't fix it. Parts unobtainable. I would like to know what others might have to say about intermittant spark and or magneto replacement for my old (1972?) Sears Suburban 12. Can parts be had? or is it a lawn ornament now? Bella
Kent of SW MO
06-01-2005 05:19:52
 Re: Sears Suburban 12 magneto in reply to Bella Kaldera, 05-30-2005 18:51:15
If the alternator stator is still good, you can modify a automotive electronic ignition pick-up to mount near the flywheel to generate a pulse and use that to trigger a GM 4 pin HEI chip and run the engine on a battery electronic ignition.
Kent
don watts
06-01-2005 05:00:46
let me check in my shop .i may have one out there.if you have the old one can u shoot me a picture and e mail it and ill chk. don
boriley
06-15-2006 16:22:26
 Re: Sears Suburban 12 magneto in reply to don watts, 06-01-2005 05:00:46
have a picture need e mail address
JT
05-31-2005 15:24:02
He is correct, the parts for that engine are no longer available. I have one in my shop right now that I am swapping engines just to get the customer going. More than likely the part number you need is 610759. been obsolete for at least 5 years.
lucasss
05-31-2005 14:45:54
the tecumseh factory rep is at perr.com in the forum. get your engine numbers and post there . he knows first hand whats available. lucas
Robin Barnard
05-30-2005 22:08:45
What brand and kind of motor is on the tractor!!
Later!!
