Old Montgomery Wards PowrKraft
bestinnett
05-29-2005 19:16:01
Old 10hp Model# TMO33876A-8162D
I broke the spring that holds tension on the mower pulleys. I've never had this one apart. Does anyone have any books, parts lists, exploded views?
jed1950
05-31-2005 21:30:40
 Re: Old Montgomery Wards PowrKraft in reply to bestinnett, 05-29-2005 19:16:01
do you still need a spring,I have some,need measurements of yours
bestinnett
06-04-2005 13:24:30
 Re: Old Montgomery Wards PowrKraft in reply to jed1950, 05-31-2005 21:30:40
Thanks Jed!
I robbed a spring from my dad's old basket case. You guys have been great! Thank you!
supergrumpy
05-30-2005 14:10:15
model number might be MTD, my monkey wards was made by MTD and I got manual with phone number from their website
but if all you need is the spring, hit the local mower repair shops with your broken spring, if they have any sort of boneyard, they will have something that will work
all you really need is good stiff spring, can use gas welding rod to make up distance
If you can find anybody at Sears parts that cares, they might be able to find something in the bins
supergrumpy
05-30-2005 14:10:09
bestinnett
06-04-2005 13:21:27
 Re: Old Montgomery Wards PowrKraft in reply to supergrumpy, 05-30-2005 14:10:09
Thanks! Problem solved! I robbed parts off an old Greenbrier my dad had sitting around. Don"t worry, his was a basket case. I do appreciate your help. Thanks again
