Kohler K301 12hp Cyl. Bore Question
BenJr
03-29-2005 06:08:06
My cylinder bore is approx. .004 - .005 out of round. All other aspects of the cylinder appear to be good. The size varies from 3.375 - 3.379. I plan to install a new piston and rod. Should I have the engined bored oversize because of it being out of round? I am concerned the rings will not seat. Thanks!
Snowplow
03-29-2005 09:21:31
 Re: Kohler K301 12hp Cyl. Bore Question in reply to BenJr, 03-29-2005 06:08:06
Yes have it bored, your rings will wear very quickly if you don't. While you re at it you might as well kick it up to a 14 hp.
BenJr
03-29-2005 09:34:14
 Re: Kohler K301 12hp Cyl. Bore Question in reply to Snowplow, 03-29-2005 09:21:31
Are there any issues kicking it up to a 16hp? I starting to like the idea of boring it out! Thanks
lucasss
03-30-2005 06:48:26
 Re: Kohler K301 12hp Cyl. Bore Question in reply to BenJr, 03-29-2005 09:34:14
you cant get it up to a 16hp bore size,youll go thru the cyl.. but remember. the thicker the cylinder the better the heat dissapation will be,and the longer life of engine. , so dont go big if you really dont have to. lucas
lucasss
03-29-2005 06:25:28
if you dont bore it, you wont get any life out of those rings. do yourself a favor and use kohler brand parts,you wont get much life out of cheep parts.. lucas
