Craftsman I/C Gold Wont Start
Avian
03-17-2005 17:21:03
I have a Craftsman IC Gold (15.5 HP B&S) that I just picked up used. I accidentally tried to start it while it was in reverse without the clutch in. It tried to start, but after that attempt, it won't even try to turn over anymore. Yargh! Any idea of what might have happened? Thanks in advance.
Andy Studt
08-04-2006 10:55:18
 Re: Craftsman I/C Gold Wont Start in reply to Avian, 03-17-2005 17:21:03
i have the same tractor. i think that you either blow the starter or you might have blown the solinoid. wait 15 minutes giving the starter time to cool. then try to crank.
DANNIE
03-18-2005 13:25:21
Check fuse or wire may have come off safety switch.
DRD
03-17-2005 21:30:21
Starter gear could be wedged in Flywheel ring gear.
Avian
03-18-2005 13:37:53
 Re: Craftsman I/C Gold Wont Start in reply to DRD, 03-17-2005 21:30:21
Thanks for the suggestions - just a followup. I got it to start -- but it I have to push the deck engage lever down manually until it hits the end of the shaft, as I turn the start key. The knob naturally sits disengaged about 3/4 of the way down the shaft). So I guess the position that the safety switch engages has changed? Any of this sound normal?
JT
03-19-2005 05:58:52
 Re: Craftsman I/C Gold Wont Start in reply to Avian, 03-18-2005 13:37:53
sounds like you may have bent the lever that engages and dissengages the blades, so it will not let the lever rest in its correct position.
