JD 110 Rear Axle
BWS
01-10-2005 04:31:07
I am restoring a 1965 JD 110. The four bolts holding the rear axle in place are loose and allow the axle to move. When I tried to tighten the first one the head snapped off.
I need to remove the entire axle and replace the broke bolt. I think they may all shear off when I try them, but I cannot get to the inside bolts. Does anyone know how to get to them?
greenmech
01-11-2005 18:43:00
 Re: JD 110 Rear Axle in reply to BWS, 01-10-2005 04:31:07
You may want to try taking out the axel by removing the rear plate holding the axel assembly, then it will be easier to work on those bolts.Good luck.
