fenders for wheelhorse
b. dunegan
10-25-2004 07:57:31
i have a restored wheelhorse c-165 auto with hydraulic lift and a full set of wh attachments, which makes for a nice setup. however my rear fenders are the fiberglass ones, and they are cracked. does anyone know where i can get a set of steel fenders?
Wheel Horse
10-25-2004 14:24:50
 Re: fenders for wheelhorse in reply to b. dunegan, 10-25-2004 07:57:31
Just to add to oldtanker"s info, a fender from any C Series will work plus the newer models. How bad are your plastic fenders? If it is just cracks, there is a technique of welding them I have found out, using a plastic welder. If chunks are missing, then it might be best to replace it. I have 3 plastic fenders, the original thin style and 2 of the newer style and I have repaired them by using fiberglass and body filler on the underside....
oldtanker
10-25-2004 14:12:52
Go to Toro's web site and get on the master parts viewer. YOu can get a steel one new I think and if so your local dealer should be able to order one in.
