Cub 1430 rear wheel removal
Big D
10-21-2004 18:52:21
I've got a 1430 with hydro or tranny problems. Am trying to remove rear wheels from axles so I can split the tranny case to inspect. Have removed 5/16 wheel retaining bolt from end of each axle and applied penetrant to soak. Tried wheel puller, heating center bore of rim, and big hammer with no luck. Ends of axles are D-shaped and appear to be press-fit into rims. Anybody out there know of any tricks to get the wheels off? Or is this just another typical MTD design. Thanks
Dannie
10-22-2004 03:38:21
 Re: Cub 1430 rear wheel removal in reply to Big D, 10-21-2004 18:52:21
I drill 2 holes in wheel and use an old steering wheel puller and two bolts.Works most of the time,some are harder to remove than others.PB Blaster helps. Good Luck....
