Ford LTG 125 No Spark
BenFord
10-16-2004 17:03:52
I bought this tractor today and there is no spark. Does anyone have any ideas on these Kohler engines that have no spark? Thanks for your help.
DANNIE
10-17-2004 06:15:33
 Re: Ford LTG 125 No Spark in reply to BenFord, 10-16-2004 17:03:52
Check out points,clean & set at .20,check wire from coil to points for breaks,check coil wire from coil to plug,be sure you have good plug.Good Luck
BenFord
10-18-2004 06:01:53
 Re: Ford LTG 125 No Spark in reply to DANNIE, 10-17-2004 06:15:33
Once I figured out where the points were located I found the problem. Cleaned them up and it started right up. Thanks
