Cub cadet Pto trouble
andy maschino
08-14-2004 11:11:14
When I engage PTO it works, but then shuts off or occaisionally stalls motor right out. Any Help?
andy maschino
08-15-2004 16:53:25
 Re: Cub cadet Pto trouble in reply to andy maschino, 08-14-2004 11:11:14
It is a electric front PTO on a Cub Cadet 680 hydro.
andymaschino
08-15-2004 17:00:45
 Re: Cub cadet Pto trouble in reply to andy maschino, 08-15-2004 16:53:25
Are these hard to change. It hakes a rattling sound as it shuts off. When it stalls motor I can turn PTO switch off and it will not disengage until motor quits and I restart. I starts right back up.
R Bedell
08-15-2004 17:16:22
 Re: Cub cadet Pto trouble in reply to andymaschino, 08-15-2004 17:00:45
Andy:
Sounds like "REPLACEMENT" time for the PTO. There is one retaining bolt w/big thick washer in the end of the crankshaft that has to be removed. Once removed, thus allows the armature to come off. The Field Coil Assembly is bolted to the crankcase with four (4) bolts. Once they are removed the field coil will come off as long as you unplug the power wire. Once you have the replacement PTO, re-assemble in reverse order. Once installed, you will have to adjust the Air Gap, and that should be about .010". The replacement PTO should have instructions for you to follow in the event you need some additional information.
R Bedell
08-14-2004 12:21:15
Ok...since I don't have a crystal ball...what is the model number of your Cub Cadet...????
JT
08-14-2004 12:46:15
 Re: Cub cadet Pto trouble in reply to R Bedell, 08-14-2004 12:21:15
R.Bedell, you are gonna have 10 years bad luck for breakin your crystal ball.
R Bedell
08-14-2004 13:00:33
 Re: Cub cadet Pto trouble in reply to JT, 08-14-2004 12:46:15
LOL..... ..!!!!
lucas
08-14-2004 15:53:52
 Re: Cub cadet Pto trouble in reply to R Bedell, 08-14-2004 13:00:33
arnt they all the same??? lol... i shouldnt harp,,, but i spend alot of time trying to help people get parts and advice and they dont know what they have... it proves one thing,,, parts men must be saints...lucas
R Bedell
08-14-2004 16:48:21
 Re: Cub cadet Pto trouble in reply to lucas, 08-14-2004 15:53:52
Well....there is a Front & Rear PTO....There is Electrical and Mechanical....and there a different version between the Electrcial and Mechanical, depending upon age...There for a Model Number would greatly narrow it down...!!!!
