case 446 running
ben rauls
07-08-2004 07:15:27
My case 446 w/ 16hp onan quit running the other day, no fuel. replaced fuel pump gaskets and ran fine. now runs for a few minutes and dies, if i put my hand over the carb and choke it it will stay running again. and suggestions, how much vacum should i have at the hose going into the fuel pump?
Max
07-09-2004 19:00:20
 Re: case 446 running in reply to ben rauls, 07-08-2004 07:15:27
Have you checked the fuel float yet? These are not as sturdy as the rest of the unit.
Bob
07-08-2004 09:20:52
If you are referring to a diaphragm fuel pump connected to the crankcase, it's not steady vacuum that operates it, but the PULSATIONS in crankcase pressure that flex the diaphragm and pump fuel. It sounds like you may have a restriction in your tank outlet fitting, fuel line, or carburetor. Is ther a filter?
