Briggs Straton 13.5hp Poulan Mower won't run with
Bhavesh
06-13-2004 15:06:46
What would be potential causes for this? What would be possible fixes for this?
The lawnmower used to run fine, but on occasion, after an hour of mowing (level land), it would sputter and die. Starting it again required the choke to continue running.
Now everytime I start it, I need the choke on completely to keep it running.
I cleaned the air filter and sprayed in some carb cleaner, but it didn't help.
If it needs choke, the only thing I can think of, is that the carb is getting air from someplace else. If that's the case, how would I find it?
Vern-MI
06-14-2004 04:42:02
 Re: Briggs Straton 13.5hp Poulan Mower won't run in reply to Bhavesh, 06-13-2004 15:06:46
Try a new spark plug. I had a similar problem with an 8 HP unit where the plug was fouled to the point it would only run with full choke. It didn't look all that bad but once a new plug was installed it ran fine without any choke.
jp
06-13-2004 19:04:05
Two answers, you must not like your john deere if you are getting fram filterd for it. The filter is the same as a briggs 491056, or kohler 52 050 02. I would not put a fram filte on a john deere to save 1.00,but your tractor, your potential loss.
As for the engine only tunning on choke. You need to take off the carb clean it completely. you have some plugged up jets. clean it good and it will run.
Frank Aldous
06-13-2004 18:42:15
This has nothing to do with this question but does anyone know a fram number for a john deere 18 h/p 318 tractor oil filter so i could get one at wal-mart .
MAC,IL
06-13-2004 16:04:38
Next time, remove the gas line from the carb and see if you have a good flow. May be the gas cap vent is clogged and tank cannot get air. Have you replaced the fuel filter.
Bhavesh
06-13-2004 17:27:04
 Re: Re: Briggs Straton 13.5hp Poulan Mower won't in reply to MAC,IL, 06-13-2004 16:04:38
I removed the gas line between the carb and fuel filter and emptied it into a gas tank. The flow was constant. I took the fuel filter apart and air-cleaned the small mesh grill; it's now clear. So I don't think it's blocking gas.
Is there a possibility that the tank does not have a gas cap vent? There's a cap, but no vent hose coming out of it. So I tried starting the mower with the gas cap loosened. It still didn't work.
I was a little nervous about removing the carb, but went ahead and did it anyways. After carefully noting bolt locations and attachments, I got it off the tractor and into the garage. It seemed ok in the main tunnel (not sure what it's called), but once I removed the float bowl on the bottom, I found a large buildup of rust and mud. I cleaned out the bowl and sprayed a carb cleaner through the smaller tunnels until no more mud dripped out, then blew compressed air to dry it up.
Then I reassembled it, and turned the key. At first it wasn't firing (which makes sense..the float bowl needs to fill up). Then it started to run, and died after 4 revolutions, or so. Now it won't even run with the choke! I can get it to fire 4 times or so, then immediately after it dies. And I even killed the battery trying to turn it over enough to start.
What options do I have left over? Do I have to get a new carb?
Bhavesh
06-13-2004 15:07:47
The title was cut off, it won't run WITHOUT CHOKE.
