BriggsStratton wont start
Antti
06-13-2004 12:26:14
I have a 10hp garden tractor with 254707-0140-01-9111131 engine. It has a electrical start but when I turn the key...nothing happens. I've checked protect-switches, but what should I check next? Any ideas? Thanks.
JP
06-13-2004 19:10:16
 Re: BriggsStratton wont start in reply to Antti, 06-13-2004 12:26:14
this engine has a dual circuit alternator if it does have lights, that means that the lights only are on when it is running. more than likely you have either bad battery connections, bad ground or a solenoid that is bad.
Antti
06-14-2004 01:01:13
 Re: Re: BriggsStratton wont start in reply to JP, 06-13-2004 19:10:16
Okay, thanks for the replies. Machine has not the lights. I try to check more those switches. Hmm, is that solenoid in the starter?
Antti
06-14-2004 06:34:36
 Re: Re: Re: BriggsStratton wont start in reply to Antti, 06-14-2004 01:01:13
Okay, now it runs again. It was some kind of connection problem. Suddenly it worked...
MAC,IL
06-13-2004 16:08:27
Still sounds like a safety switch issue. SOme mowers have an inline fuse also. As other poster suggests, try the lights and see if they work.
Ron
06-13-2004 12:39:22
Turn the lights on and then tell us what happens.
