Dixie Chopper 20 HP Kohler
Barry in Indian
05-24-2004 04:02:17
A while back I posted a message concerning my Dixie Chopper 20 HP Kohler constantly fouling one plug and using about a 1/2 quart of oil in 3 hours of use. The plug fouls so bad that the cylinder will quit firing. When I pull the plug the tip is covered in oil and crispy gunk. It doesn't smoke at all. My question was is it rings or valves. Someone posted that the Kohler command 20 blows head gaskets and that was probably my problem. I'm finally getting around to having time to work on it. Could a blown head gasket cause it to use oil and foul the plug this way?
Barry in Indiana
JP
05-24-2004 12:08:40
 Re: Dixie Chopper 20 HP Kohler in reply to Barry in Indiana, 05-24-2004 04:02:17
Yes, a blown gasket can cause it to use oil and foul plugs. They commonly blow between the pushrod chamber and the cylinder, so that can cause and does cause the problem you describe.
lucas
05-24-2004 05:58:29
if your compression is good, i would try a new valve seal on the oily cylinder first...lucas
Ron
05-24-2004 04:57:45
No. A standard compression test will reveal if rings or valves. At that level of oil use, I'm betting on rings.
In the meantime, use a platinum plug. They will not oil foul. But the engine should be torn down and repaired.
