Cub Cadet 1320
Andy
05-16-2004 18:17:01
The other day the Kohler 12.5 quit on my Cub Cadet 1320 while I was mowing my lawn - no spark. I pulled the flywheel off the motor and found that two of the magnets came loose, one broke in half. I glued them back in with Seal-All, but still no spark. I looked at the coil and noticed the epoxy coating was cracked so I replaced it and finally got it runing. My question is will gluing the magnets back into the flywheel cause problems later? It loks like they were just glued in at the factory, and if I have to replace the coil ($35.00) AND the flywheel ($175) I might as well have replaced the motor with a new replacement.
