98 Dynamark help
Andy
03-12-2004 11:07:18
I have a Dynamark Riding mower model#42534X18A that won't start. I have replaced the ignition, solenoid, starter and battery. I'm not sure if I have all the wires properly connected to the solenoid. On the two terminals I have the thicker red wires. If I'm looking at the solenoid from the seat. The terminal on the left is for the battery. The terminal on the right is for the red wire that goes to the starter, On the post I have a black wire. I still have two wires that I'm not sure about. One is green and the other is a thin red wire.
What do I have to do to try and jump the solenoid?
John McPherson
03-12-2004 19:16:12
 Re: 98 Dynamark help in reply to Andy, 03-12-2004 11:07:18
2 ways to jumper the solenoid-
1) directly across the large lugs with a wrench or a screw driver.
2) with a wire from the battery "+" touched to the small terminal
The thin red wire likely goes to the small terminal- this should only show a voltage when the key turned to "start" with someone seated on the seat, and the blade up/disengaged. Otherwise the green and the small red are swapped.
The green one on a guess is likely to go to the battery side of the solenoid.
Do all tests like this with the tractor in neutral only and blade disengaged or removed!
Note that there will be a switch under the seat and possibly one that is aet to be closed when the blade is in the "up/disnegaged postion".
There is a small chance that there may be an additional switch on the clutch pedal.
If you try to run the tractor while bypassing the starting solenoid, and you want the engine to start- turn the key to the "run" position.
If you do not own an ohm meter/multimeter, now maybe a good time to invest in one. Home centers, radio shack, Harbor Freight, etc have inexpensive ones and it will help you in locating defective switches, shorted wiring, broken wiring, etc.
