prime line engine parts
darrel
03-04-2004 16:31:18
has anyone used prime line engine parts? pistons and rings +.030(for a k532 kohler) or should I stick to kohler parts tia
Darrel
mike
03-05-2004 11:37:53
 Re: prime line engine parts in reply to darrel, 03-04-2004 16:31:18
i called the primeline co. and they told me they have a one year no hassle warranty policy.they told me where to see it but im not a dealer so i dont have the parts books.i was curious because i use alot of their stuff.. mike
jim
03-05-2004 10:22:44
I am not sure of the quality of prime lines engine parts, I have seen some of theri stuff, and am not real sure of it. I use Stens a lot, they also offer a one year warranty on their parts, ask prime line what kind of warranty they offer of their parts, I do not know of any they have. If they will not warranty it, it does not get used in my shop.
mike
03-04-2004 18:24:50
i have used primeline pistons for years in kohlers that work alot of hours and have had no complaints.welders,tractors,generators...but i allways bore the cylinders.youll have trouble with any piston or rings if you put it in a worn out cylinder.they look like oem to me. mike
Brian G. NY
03-05-2004 06:47:11
 Re: Re: prime line engine parts in reply to mike, 03-04-2004 18:24:50
Mike, you're so right about the worn cylinder bore. I bought a used tractor 2 years ago with a Kohler K321 engine. I used it most of last winter with a snowblower and most of last summer with a mower. The old guy (original owner) who I bought it from told me it had been rebuilt with new piston, rings, rod and valves. It developed a serious knock late last summner so I took it out of service. I pulled the engine apart yesterday and the cylinder is really worn and egg shaped. The top ring broke and really "screwed up" that practically brand new piston. When the piston was at the bottom of the bore, you could see half of the top ring alongside the piston. A rebore and an O.S. piston should put me back in business.
John McPherson
03-04-2004 16:35:16
They are a respectable aftermarket supplier. I would have no hesitation using the pistons and rings, in part because they are cheaper, but also because most manufacturers use various manufacturers of those parts depending on economics at the time of the production run.
