kohler engines
Ben J
01-30-2004 21:12:45
Does anyone know what the differences are in the Kohler command horizontal shaft engines ranging from 18-22hp. The dimmensions are all the same including bore, stroke, and displacement. Is the carb. the deciding factor in horsepower.
lucas
01-31-2004 05:44:55
 Re: kohler engines in reply to Ben J, 01-30-2004 21:12:45
have rebuilt them all,pistons rods cam crank are the same on the inside. i know the carb jetting and rpm gov setup is diff.the 18hp has a brass rod that screws into the carb restricting wide open throttle, remove it change the gov spring and youve got a 20hp.22 hp has larger carb jetting.lucas
sgmbabby
01-31-2004 03:26:44
You can download Kohler Engine Manuals Free from Website. That would give you alot of info.
Link
