cub cadet 128 crankshaft help
Barry
12-22-2003 14:40:14
Gentlemen....
appreciate all the good info here. I'm rebuilding a kohler 12 horse (K301A) for a cub cadet 128 and the crankshaft is bad....I have a K241 10 horse laying around but havn't broke into it to look at the crank ....would these be the same crankshafts?
Can i use a K241 crank on a K301A....Thanks in advance...
Barry
jim
12-23-2003 12:40:59
 Re: cub cadet 128 crankshaft help in reply to Barry, 12-22-2003 14:40:14
Depending on what machine shop you use, they might be able to grind the crank down and machine your old rod out and have them put a Renault rod bearing insert in the rod. I know it can be done, a friend of mine had it done, and it worked great. You might call around and ask if any of them have the ability to do this.
Kent of SW MO
12-23-2003 08:14:19
No k241 is a shorter stroke than a K301 if I remember right. I will check my books and get back to you if I am wrong. Send your K301 crank to a good shop that can weld it up and then regrind it.
Barry
12-23-2003 10:01:57
 Re: Re: cub cadet 128 crankshaft help in reply to Kent of SW MO, 12-23-2003 08:14:19
Kent and Lucas...
Thanks for the info. I took my old crank to an auto machine shop...They told me it had been ground once before, I asked about welding to build it up, but they told me it couldn't be done.....(small town).....appreciate any info you can share.....Thanks
Barry
lucas
12-22-2003 15:13:52
the k241-10hp shaft will not work in the k301-12hp... but the k321-14hp and k341-16 hp cranks will fit the k301-12hp. lucas
KennyW
12-23-2003 17:29:56
 Re: Re: cub cadet 128 crankshaft help in reply to lucas, 12-22-2003 15:13:52
Call Scott Madson at Madson's Service 920-773-2661, he stocks reground cranks (-.010) for the K Series Cubs. Good prices and fast service. And by the way, a good small engine shop will have a source for plasma spraying a crank to build up the journal. I just find it cheaper getting a reground one from Scott. Kenny
