JD 110 WHICH GREEN
BUBSDAD
11-21-2003 13:57:37
WHICH JD GREEN DOES A 72 110 AND A #80 DUMP CART REQUIRE???
125 Hydro
11-22-2003 06:16:38
 Re: JD 110 WHICH GREEN in reply to BUBSDAD, 11-21-2003 13:57:37
As far as I know there is only one color John Deere green. The different shades that you may notice are from being exposed to the outdoor elements for prolonged periods. Different manufacturers of the color, etc. If you want true John Deere green and yellow then go to the local john Deere dealer. Any automotive store should be able to mix a good qulity match using automotive grade paint. Most of your cheaper paints are only to prevent rust on exposed metals. Hope this helps.
Dave
11-22-2003 13:11:30
 Re: Re: JD 110 WHICH GREEN in reply to 125 Hydro, 11-22-2003 06:16:38
Yes, there is more than one green. I did a 112 in JD classic green and liked the more faded look. Then there is the brighter shade that you see on new tractors. JD green paint shades varies from one brand to another. At any rate, no paint will match unless you paint the entire tractor.
