John deere 70 mower
Bfarmall
11-13-2003 06:47:18
I am looking at buying a 70, However I don't have any info on them. Can anyone tell me what they come with standard? IE gear driven, Hydro, HP is the engine shaft Horizontal or vert. This is a round fender mower and I am not sure of the year. Thanks for any help!
Irv Slagter
11-13-2003 10:48:08
 Re: John deere 70 mower in reply to Bfarmall, 11-13-2003 06:47:18
The model 60, I think, was first made in '65 but I'm not sure how long it was before the 70 came along. I think 70's were made in the late 60's. A 70 had a 7 hp Tecumseh vertical shaft engine, and a gear driven, 3 spd cast iron Peerless transaxle. Irv
Bfarmall
11-13-2003 11:12:24
 Re: Re: John deere 70 mower in reply to Irv Slagter, 11-13-2003 10:48:08
Their is a small lever on the right side of the tractor as you sit on it? What is that for?
Irv Slagter
11-13-2003 14:27:53
 Re: Re: Re: John deere 70 mower in reply to Bfarmall, 11-13-2003 11:12:24
If its up on the side of the cowl, it mechanically engages the clutch for the deck. The clutch is a tapered cone affair with the cup side on the motor and a cone that has a v-velt pulley made right in it on the bottom. There is a stub shaft in a bearing mounted on the bottom of the cone( drive pulley) that straddles a bar thats links to the handle you saw. When you over center the lever it raises the clutch up and engages the deck. Golllll y, clear as mud ain't it. < grin > Hope this helps.
Irv
