John Deere 68 rear engine lawn tractor Trans.
screaminghollow
09-27-2003 21:16:58
Paid a few bucks for above mower today for the kids to drive around. We definitely tried it out and it ran around fine. Brought it home and it wouldn't go. Started checking things and eventually took the top off the Tecomseh/Peerless transmission. Two gears were crumbled to pieces and were stuck between the other gears. Pulled them out thinking maybe the thing would run in the other gears. No such luck! The engine runs great and I'd hate to trash the mower. Are parts available for these old things?
Terry
11-07-2003 17:56:57
 Re: John Deere 68 rear engine lawn tractor Trans. in reply to screaminghollow, 09-27-2003 21:16:58
I have a JD Model 68 that I need the axle/differential for. The rest of the mower is fine. Anybody got one they want to get rid of cheap?
green dean
09-28-2003 20:45:43
The model 68 rear engine rider does not use a 2300 series peerless as Lars thinks. A 110 or 112 yes, but not your rider. Check with a JD dealer. There parts online shows that you can get what your need.
screaminghollow
09-29-2003 08:05:56
 Re: Re: John Deere 68 rear engine lawn tractor Tra in reply to green dean, 09-28-2003 20:45:43
Model 68 has a Peerless Model 739 trans. When my son took it apart, it wouldn't turn at all. We fished about a dozen broken pieces of gears out of the trans. still won't turn. I suspect some prior owner took it apart and just slapped it back. (No gasket on trans when he took it apart.) It was just for the kids to drive around, so I don't care if the thing has all the gears., one forward and reverse would be nice. A fella near here offered me an old small rider which he says is in good working shape but needs an engine. He took the engine to put on something else. It was an 8 hp verticle shaft front engine. The JD model 68 has an interesting differential which we might be able to use on the kids' go kart. Also, there's a local lawn mower repair shop selling out next week and maybe I can get a trans there.
dave boothby
09-28-2003 20:40:14
I have a peerless transmission . and rear end that i will sell . you that shifts fine. in all gears. come out of a rear engine rider. the same kind that you need .priced reasonable. chain included. i am in southern ohio .dave b .
Lars
09-28-2003 11:06:32
yup parts still available for them old 2300 series,w.j cunnel in foxboro mass. has the gears
or tucumseh/peerles an tecumseh is on the web too as they still make the peerless transaxle does as they still makem.they cost ya tho an maybe findin nuther ol tractor will be better option,get new detent springs and balls for the shifter forks as well and a gasket for the case,one broke shifter spring will do ya in as it did mine,i did get lucky here tho and a poster sold me some gears for mine out of a tranny he had.make sure to get the shop manual sm-2088-nov-69 which covers the 110-112 frtom serial number 100,001-250,000 and up.the 2300 gears will fit the 2316a peerless transaxles too.
