Deck belt slips
Ben Harrison
09-18-2003 10:56:07
I have an MTD lawnflite (dont know model), and when you go through grass abit long the belt slips, it is quite tight - any suggestions appreciated. thanks in advance
Dave
09-20-2003 05:56:28
 Re: Deck belt slips in reply to Ben Harrison, 09-18-2003 10:56:07
Ben, Take the belt off and check to see how the blades spin. If all the other things are fine (ie. belt,pulleys) you may have a bad bearing or two. A few bad bearings will result in lower blade rpm under load.
Dave
Vern
09-19-2003 00:40:40
Check to see if the belt is running in the bottom of the pulleys. It may be worn to that extent & will need replacing.
Frank Brunke
09-18-2003 17:16:00
2 Things.
1. Commercial belt dressing. Comes in a spray can. spray in on the glazed surfaces of the belt. worked for me in the past.
2. Belt rosen. My dad had, and I still have a tube of a hard black material that was applied to belts to increase friction and eliminate slipping. tube is about 2 inches in dia. very hard and black. must be 50 years old lt least. still works. apply to running belt, watch fingers.
maybe get some at at power transmission dealer.
LUCAS
09-18-2003 17:00:01
you may have a glazed belt or oil soaked belt,,, if so they cant be fixed you must replace the belt. lucas
Ollie
09-18-2003 16:40:40
Look at the belt surfaces on the pulleys. They can become glazed resulting in slipping. You can roughen them up with a scotchbrite pad, sandpaper, or coarse steel wool with the belt off. Also, if the belt gets any silicone or other oil on it, it will slip. Can't clean a belt, you'll have to replace it.
Ollie
09-18-2003 15:39:03
lucas
09-18-2003 13:45:22
be sure your blades are sharp and the engine is full throttle and slow down ground speed..remember,,its a lawn mower not a bushhog.. lucas
