Kohler Magnum 20 - No Hot Re-Start
Andy
09-10-2003 20:17:55
Hello, folks.
I have a Craftsman lawn tractor with a 20HP Kohler Magnum engine. (Inherited it with the new house last fall, so I don't know all the history.) On the first start, whether it's 50 deg or 85 deg., 3/4 to full choke, and 3/4 throttle fires immediately. I can then open the choke and throttle down to warm up for five minutes or so. (It will go right into running full throttle with no choke, too, but I generally don't do that). No hestitation, and engine runs great with full power while mowing.
My problem comes when attempting to re-start a warm engine. It will not re-fire no matter what the combination of choke/throttle, and seems to be flooded; however, remove the plugs and they are dry.
Air filter and fuel filter are new. Plugs are old, and will be replaced, but cleaning and re-gapping did not help. Only after everything cools off will it re-start, and then with no choke (or throttle) needed.
Time for a carb rebuild?
Thanks for any responses.
Andy
clifford c benjamin
09-23-2003 19:42:15
 Re: Kohler Magnum 20 - No Hot Re-Start in reply to Andy, 09-10-2003 20:17:55
un hook the oil pressure switch. pull plugs.take a pair of plastic pliers hold the plug wire near ground. turn it over checking for spark.no spark.electronic module on blower houseing. pull the blower houseing.get to new coils.in the box there is a peice of paper that explains what you need to look for on the old coils. there is a number on the flat top side of the coil. if its not what they are looking for that number change both coils watching the routing take each wire to each terminal take one wire of and swap each one at time on each coil also put the coil back and lock down after setting the air gap of each coil put all back to gether. then start it up. you should be able to do this hot or cold give it a try. i had the same problem on another tractor it can drive you nuts but don't give up hope. i hope i have been of some help to you
Andy
09-13-2003 17:59:10
Well, all seemed fine last night after changing the plugs, so I buttoned up the tractor. This morning, though 15 minutes was enough for her to say "Nope. Not gonna start no more, no more." Hooked up a timing light to one of the plugs, tuned it over, and no flashety-flashety. Pulled the dead-man wire form the Ignition module, and still no light. Cranked one more time, and fired right up. What the???? Tapped the ignition module with a hammer, and she died right there.
Well, $80 and 20 minutes later, a new ignition module fixed the problem. Used the thing all day hauling much around the yard with nary a hiccup. In fact, the "puff/poof" I was hearing in the exhaust is gone, and it runs smoother than ever.
Thanks everyone for your help.
Andy
Jim S.
09-12-2003 07:36:57
Andy:
Here is what I found out about our mutual problem from my friend I call The Master, who works for Cub Cadet:
The condition is most likely a vapor lock, and there are a few things you can do about it.
First, install a turbolizer kit. This is an easy baffle to install that goes between the carb and the intake, and frequently helps with this condition and with loping at idle. (That won't help mine, I have it on there already.)
The carb may be in need of a rebuild, or it may need the float set richer. Most of these Mags used a Walbro carb with no high-speed adjustment needle, to please the EPA. There is a variable jet instead that moves inside the carb body, and it can malfunction as it gums up. (This is likely my problem, as the plugs read lean and sometimes even after a rebuild, which I have done, the carb still won't perform right.)
In my case, he says the best overall solution will be to replace the carb with a KT-17 carb, where I can have an idle and high speed adjustment screw. Then I can richen the mix for best performance. Second best is a new variable jet carb.
Also, I might add that HVAC suppliers and installers often have insulation for small tubing that you can buy and slip over the gas lines to help keep fuel cool and prevent vapor lock. I have noticed they do use that on the newer CCs with Command engines.
Hope it helps ya out. Heck, I hope it helps ME out. ;-)
andy
09-12-2003 13:56:43
 Re: Re: Kohler Magnum 20 - No Hot Re-Start in reply to Jim S., 09-12-2003 07:36:57
JIm,
Thaks for consulting Master Yoda on the matter. Vapor lock is looking more and more like the culprit, but the "puff/poof" I am hearing still has me wondering about the ignition module. The "turbolizer" sounds like a performance spacer one would put under a Holley 850 on a built 350. Hmmm.... 20 HP now, 200 with a carb spacer??? Muahh-ha-ha-ha!
Thanks. I'll keep you (and evryone) posted.
Andy
Andy
09-12-2003 06:40:06
Thanks again for all the comments.
I pulled the covers off the engine sides last night, and discovered that Mrs. Mouse had built a nest under the left-side cover. (I won't detail my findings, but let's just say she won't do it again.) Cooling on that side was definitely compromised.
I also changed out the plugs (which I found were two heat ranges too low, and actually an automotive plug).
Buttoned everything back up, and ran at full throttle for about 30 minutes, and couldn't duplicate the problem.
One thing I did notice, though, is that while running full-throttle, there is an occasional "poof" sound in the exhaust. I never noticed it with ear defenders on and the blades turning. Maybe I *do* have an ignition module that's starting to go south. Time will tell, since the grass is still growing, and I'll be mowing again soon. If she doesn't start up after that, I'll check the module, and the ignition wiring.
Vern-MI
09-11-2003 14:25:33
Just a guess. To much gas caused by overheated fuel system, gas line and/or carburetor. Cool carb and fuel line with warm water and if that helps then install an aluminum spacer plate of 14 or 16 gage stock between carb and intake manifold (larger the better)and/or re-route fuel line away from heat source for additional cooling.
Are cooling fins and shroud clear of debris for optimum cooling?
JEROME
09-11-2003 10:32:22
I agree with all the others. It may also be valve clearance. If it ain't fuel or fire, check the valve clearance.
peter
09-11-2003 10:28:43
do some backwoods troubleshooting first
buy a can of ether (says starting fluid on the can)
when it won't start - take off the air cleaner and spray a teeny bit into the carb - crank it right away
if it fires, you have a fuel starvation problem
if it doesn't fire, you have lack of ignition
ether can destroy things if overused
Jim S.
09-11-2003 11:05:39
 Re: Re: Kohler Magnum 20 - No Hot Re-Start in reply to peter, 09-11-2003 10:28:43
Warning, just so you know. If you use ether, yer running the risk of ruining yer engine or blowing off a head.
Ollie
09-11-2003 11:39:55
 Re: Re: Re: Kohler Magnum 20 - No Hot Re-Start in reply to Jim S., 09-11-2003 11:05:39
100% correct! Never use ether. Use carburetor/choke cleaner. I use B12-Chemtool.
andy
09-11-2003 13:24:20
 Re: Re: Re: Re: Kohler Magnum 20 - No Hot Re-Start in reply to Ollie, 09-11-2003 11:39:55
Thanks for all the input. Looks like I'll have some work to do tonight.
I ruled out the ignition module at first, since it *runs* fine, but simply won't re-start. Electronics gremlins like to do strange things, tho. Will a direct-connect timing light suffice as a plug tester?
I'll also look at the cooling fins, etc. and make sure there's no obstruction, and play some compressed air on the carb to cool it off to rule out (or find) vapor lock.
Don't know if I have the low oil switch or not, but could be the culprit, as well; however, does this switch cut the motor while running (i.e. grounding the ignition), or only prevent it from starting (by interfacing with the start circuit)?
Just as a note, in the "hot-no-start" condition, I've seen a small amount of fuel in the carb throat. Seems strange it would be there. Could've boiled back due to vapor lock??
Ron
09-10-2003 20:27:53
Andy, Before you go any farther you have to establish if you have any spark when you try to restart. I have seen some strange things happen to the ignition modules. If you don't have spark, you can remove the kill wire coming off of the module. Then try again, if still no spark, the module is bad.
Jim S.
09-11-2003 06:44:43
 Re: Re: Kohler Magnum 20 - No Hot Re-Start in reply to Ron, 09-10-2003 20:27:53
I have the same trouble with a Mag 18...runs great, but don't shut it off til yer done. Plugs seem to have fire when I jerk one out. They are new, the engine was just totally rebuilt and has about 20 hours on it. Reading the plugs, they do look like it is running lean...kinda whitish. And I know the later "EPA carbs" gave trouble. But dribbling gas into the carb throat won't start it, either. Let it cool, it pops right off.
I'm kinda stumped, and have just lived with it. Suggestions?
Ollie
09-11-2003 07:51:25
 Re: Re: Re: Kohler Magnum 20 - No Hot Re-Start in reply to Jim S., 09-11-2003 06:44:43
You have to approach this like any other "won't start" problem; verify you actually have a spark at the plug (use a tester) and that you have fuel in the cylinder (turn it over with the plug out).
Ignition modules can cause this but more likely it's high resistance at a terminal due to dirt/corrosion. However, "vapor lock" due to the carburetor being heat soaked after stopping is much more likely. You can easily test this... pour warm (not cold) water on the carb for a minute or two and then try to start it. If you use cold water you will crack the head. Vapor lock can be caused by poor quality gas, wrong gas (winter gas being used during the summer, they are different), some additives in the gas, engine running too hot due to wrong timing, cooling fans/shrouds missing/damaged, dirt/grass clogged fins on head/shrouds, exhaust restricted due to wrong/damaged muffler.
If the plugs read lean, overheating is almost certainly the problem.
nazareno perez
10-29-2003 14:45:34
 Re: Re: Re: Re: Kohler Magnum 20 - No Hot Re-Start in reply to Ollie, 09-11-2003 07:51:25
estoy solicitando la puerta izquierda y el sistema de enganche de la cabina con sus amortiguadores de una magnun con numero de serie
T2Q6L1A00V3AA4386M POR FAVOR SI ME PUEDEN AYUDAR CON ESTO O SI CONOCEN LA COMPAŅIA QUE ESTA VENDIENDO ESTAS PIEZAS
Jim S.
09-11-2003 11:03:45
Thanks, but like I said, it has spark when hot. I have many years of small engine experience and newly rebuilt it all the way (not a cheapo job) and cleaned it up. Dribbling gas in the carb doesn't start it hot, even with full choke afterward. Starts fine cold. There's no dirt issue at all. I had thought of vapor lock, and am leaning toward resetting the float richer or subbing a KT-17 carb on it so I will have a high speed richness screw to adjust. Lots of guys have done that.
It stumps me why it won't even try to fire with gas in the carb throat/manifold. That would indicate no spark. But pull a plug, and you'll get spark. This engine comes with the Oil Sentry feature, and I wondered if somehow the switch (which is brand spanking new from Kohler) could be shutting it down like there's low oil pressure. I have had some trouble with Kohler-supplied parts before. I may try getting it hot and then jumpering that to see if it makes a difference on restart. Or it could be a defective wire to the switch, too, I guess.
It's not many engines that stump me, but this one is one of 'em. Appeciate the input.
Ollie
09-11-2003 11:38:09
 Re: Re: Re: Re: Re: Kohler Magnum 20 - No Hot Re-S in reply to Jim S., 09-11-2003 11:03:45
A common misconception is that if a plug fires outside the combustion chamber it will fire inside as well. A weak ignition will often fire in open air fine, but fail to fire at all under 8 or 9 to 1 compression. This is why I use a plug tester. You attach it to the plug wire with the plug in the cylinder and (try to) start it. The tester light will come on only if the plug actually fires in the cylinder. Any auto parts store has them.
Yes, a faulty oil pressure switch or wiring can cause the problem as well.
Jim S.
09-11-2003 11:57:44
 Re: Re: Re: Re: Re: Re: Kohler Magnum 20 - No Hot in reply to Ollie, 09-11-2003 11:38:09
I got one. It fires. Thanks.
