Need Peerless Transaxle Info
Ash
08-18-2003 06:35:26
Working on a Tractor Supply Co. lawn tractor made by NOMA. TSC model # 44-20189 manufacture # D4318050. Need reverse gear and shift keys. The transaxle is made by Peerless but someone had it apart before and lost the model tag. It looks like a 900 series maybe 915 or 940. Thanks Ash
clifford c benjamin
09-29-2003 10:44:11
 Re: Need Peerless Transaxle Info in reply to Ash, 08-18-2003 06:35:26
noma is a murray.get hold of gardner at 1-800-521-6535./in columbus ohio www.gardnerinc.com.they handle./dana/foote-hydro-gear.i hope i have been of some help to you
joe
10-24-2003 18:21:12
 Re: Re: Need Peerless Transaxle Info in reply to clifford c benjamin, 09-29-2003 10:44:11
I have a lawnchief with a rear axle that looks like a peerless transaxle, I need to know how to check and lubricate the rear gear box, I can not find plug any where?
Lou
08-19-2003 06:13:48
Link
rwp
08-18-2003 19:37:44
Ash: Since you don't know the model number of your Peerless transaxle, and if I had your model number, I could do some research. Why don't you try going to Link They use the Tecumseh Peerless since 1966 - 1979. Some of the ones they use in 1966 are the 770, 775, 773, 736, 510, 610, 613, and 813. In 1977 the G8; in 1979 the LT8, the LT8E, the G11XL, the G14XL and the G16XL. Call Sonny and he may be able to help you with your parts.
JDK
08-18-2003 06:51:03
Peerless is a division of Tecumseh,Parts avaolable thru Tec dealers.
Ash
08-18-2003 07:10:15
 Re: Re: Need Peerless Transaxle Info in reply to JDK, 08-18-2003 06:51:03
Yes I know Peerless is a division of Tecumseh and I work for a dealer now. The problem is we can't match up the reverse gear with anything we have. We really need the model number of the transmission before ordering parts, was hoping someone could look up the Noma numbers and find the transaxle model that way (we can't). Thanks again, Ash
JDK
08-19-2003 05:43:52
 Re: Re: Re: Need Peerless Transaxle Info in reply to Ash, 08-18-2003 07:10:15
Believe Noma currently owned by Murray.May be able to get parts sheet there listing TA model.
