Need help on a simplicity mower
ashenfang
08-17-2003 08:44:56
Hi all, I have aquired a Simplicity Broadmoore III, I believe it was manufactured in 1979. Anyway, we bought a new house, and i had this one and a Lawn chief sitting in the back garage. I was trying to figure out which one I should get working. (being that I only had a push mower, and two acres to mow i needed one of them) So i figured getting the simplicity going would be more worth while. So, I cleaned it up, bought a new battery, and sprayed some starter fluid in the carb and she fired right up! So i started mowing the lawn and worked great for about an hour, then, i started to notice this sudden power loss, especially when you engaged the blades, then it started just doing it idle-full power, then would start to stutter, then die out. I check gas, gas was good, no loose wires or anything.
So i messed around with it for a bit, and found that if i start it up with full choke, fires right up, but if i push it back in to normal, it will die. If i leave it on full choke, runs great. Whats the deal here? So, just trying to figure out whats causing this, i assume something with the carb.
On a second note, i washed her down before putting her away after mowing the lawn, and when i went to turn the key off, i was shocked (well more like nipped) but enough to notice. I am pretty sure it had something to do with water sill being on the deck/frame. Well thanks for any info!
kjm
08-17-2003 16:14:35
 Re: Need help on a simplicity mower in reply to ashenfang, 08-17-2003 08:44:56
Be carful when you wash the mower,water will stand around the bearings in the deck and will rust out the deck as well as the bearings.
DAVE
08-17-2003 09:06:34
your carb has someing chokeing off the gas need to clean and rebuild card DAVE
ashenfang
08-17-2003 09:55:29
 Re: Re: Need help on a simplicity mower in reply to DAVE, 08-17-2003 09:06:34
Thanks for your response. I was thinking thats what it was, its an old briggs cast iron i believe, (vtwin) 15 Horse. Any suggestions on where to find a manual on parts/areas to clean rebuild on these carbs?
Dave
08-17-2003 10:19:15
 Re: Re: Re: Need help on a simplicity mower in reply to ashenfang, 08-17-2003 09:55:29
Hello, If the mower was sitting awhile and it was either outside or sitting for awhile, check the gas tank and make sure there is no rust or dirt in the way of the fuel opening. I had the same problem with a Ford 120, it had a small screen in the tank and was clogged with rust and debris.
As far as manuals go you can goto the simplicity web site>Link
make>Link sure you have the serial number and model number. If they don't have your manual online(pdf format) then you can call them and get the manual shipped to you. This worked for me with a 1968 yoeman.
Good luck.
Dave
Dennis
08-17-2003 14:18:21
 Re: Re: Re: Re: Need help on a simplicity mower in reply to Dave, 08-17-2003 10:19:15
If you still have trouble go to: Simpletractors.com
It's the web site for the Simplicity/Allis Garden Tractor Club. Lots of help there.
