Kohler 18hp magnum - spewing oil
B Harmon
07-27-2003 09:51:30
I have an 18hp Kohler magnum v-twin on a ford lawn tractor. I have excessive oil spewing from under the engine ferrings. At first I thought it was blowing out from a cover in the valley so I cleaned it up and replaced the gasket. I filled it with oil and let it run to warm up and check for any more leaks. It still leaks excessively but I don't know where to start, any ideas?
Dave
07-29-2003 20:25:58
 Re: Kohler 18hp magnum - spewing oil in reply to B Harmon, 07-27-2003 09:51:30
Had oil leak on rebuilt Mag 18 and it was coming from the gasket in the front where the oil filter lines attach. They can get old and brittle I was told. Just trying to help.
Gene Davis
07-27-2003 20:16:03
My 18 hp magnum repair book states that the crankcase operates under a slight vacuum,sounds like the crankcase breather valve may be going bad, letting it build up pressure. Gene D.
Bob
07-27-2003 11:08:46
My first guess would be that you have a bad piston/rings/bore, and excessive blowby is forcing oil out the crankcase breather... the tube that comes out in the top center area of the engine, and makes a "U" bend, and discharges into the cooling stream of the RH cylinder.
Other possiblities would include a bad crankshaft seal under the flywheel, or a gasket leak at the joint of one of the cylinders to the crankcase.
