JD STX 38
Big Daddy
07-16-2003 18:21:26
I have a John Deere STX 38 hydrostatic 38" mower that will occasionally not move forward when the lever is in the forward position. However, you can put the lever in reverse and then into forward and it will go forward. Does anybody know what the problem could be? I have checked the oil and the oil seems to be okay. Thanks!
Rick
07-17-2003 13:24:53
 Re: JD STX 38 in reply to Big Daddy, 07-16-2003 18:21:26
Sounds like you have a valve that is sticking. If it has a transmission oil filter try changing the oil and filter.
Big Daddy
07-20-2003 16:51:21
 Re: Re: JD STX 38 in reply to Rick, 07-17-2003 13:24:53
thanks for answering my question ,that is the advice 2 others have offered ,the only probelm is this unit does not have a drain or a filter , if
