John deere 175 hydro
b steele
07-01-2003 19:30:02
I have a 175 hydro trying to find out what is the right drive belt, tried to contact john deereit gives two belts one is 79 1/3 inches long and the other is 78 1/2 inches long i have the part #s for these belts but one i took off is only 77 inches long measured it several times and it is a john deere belt but its worn to bad to read any #s,,Thanks for any help.
JDOUG
07-02-2003 05:08:34
 Re: john deere 175 hydro in reply to b steele, 07-01-2003 19:30:02
I'm assuming that your looking for the hydro drive belt. The correct belt is M84075. This is the shorter of the 2 that are listed and is the one you should use. The original belt was the longer one and would slip over time. I'm not sure why your old belt measures 77". When you put the new belt on it will probably seem to short but it will go on if you pivot the tightener arm all the way up and back.
b.steele
07-02-2003 19:38:02
 Re: Re: john deere 175 hydro in reply to JDOUG, 07-02-2003 05:08:34
Thanks, i ordered that belt today,it won't be here until monday,will reply if problem solved
Bruce
07-09-2003 20:31:25
 Re: Re: Re: john deere 175 hydro in reply to b.steele, 07-02-2003 19:38:02
tried the shorter belt and a new fan took care of my problem.
