How do I drain my cub 125 hyd trans fluid???
Andy
06-12-2003 13:47:45
I want to change fluid and filter in my cub 125. I blocked the rear up and loosened the lowest steel hyd line on the fron of the transmission casing; nothing came out. It worked OK but was surgey. Is this the right spot??? thanks
Red Dave
06-13-2003 12:17:22
 Re: How do I drain my cub 125 hyd trans fluid??? in reply to Andy, 06-12-2003 13:47:45
Go to a Cub Cadet dealer and buy the gasket for the rear cover and a spin-on filter.
Put a wide pan under the rear end and remove the bolts from the rear cover. Oil will come out.
Clean out inside bottom of the rearend with a clean rag then clean all the old gasket off the cover and the housing. Place cover back on with new gasket. Replace filter & refill with 7 quarts of Case/IH Hytran fluid through the plug on the rear cover (a long flexible funnel helps a lot).
Works that way on my 123 & 125.
125 Hydro
06-13-2003 09:51:06
Link
Here is an excellent site where you can get help including pictures that are posted to help with your problem. I think that this will help guide you through this much better than trying to explain here. Feel free to join.
rick
06-13-2003 07:34:43
There is a drain plug on the bottom of the tranny
Andy
06-14-2003 06:19:24
 Re: Re: How do I drain my cub 125 hyd trans fluid? in reply to rick, 06-13-2003 07:34:43
There is no drain plug on the bottom of this one.
Red Dave
06-15-2003 17:42:02
 Re: Re: Re: How do I drain my cub 125 hyd trans fl in reply to Andy, 06-14-2003 06:19:24
There is no drain plug on that vintage IH hydros.
You have to take off the cover.
