JD 318 surging
bern
05-22-2003 05:44:23
JD 318 is surging from idle to very high rpm. The engine also vibrates alot. Please help.
Pat
05-26-2003 10:04:44
 Re: JD 318 surging in reply to bern, 05-22-2003 05:44:23
Hi Bern! The other thing the onan engine does is leak air at where the intake manifold bolts to the tractor. This happens a lot.
Wally G.
05-22-2003 15:04:46
On your carb is a little metal plug about the size of a pencil eraser that seals the drilled passage for the mixture screw. Seems some of these pop out and it runs like crap. Take carb off and look under mounting flange for the little plug and put it back on by staking with a punch and hammer then seal the outside with a dab of silicone sealer.
